CEL Again. Help please P0170
P0170 Fuel Trim Malfunction(Bank 1) We ran the code in the computer and it gave a list of things it could be. It does start rough sometimes so I dont know if that could be a clue to the problem. Last fall when it was put away it threw another code which was Fuel Pressure Solenoid. I dont remember the number of the code but that could be a contribution to the problem. It runs fine its just that it starts rough sometimes. Where do we start for this one?
RE: CEL Again. Help please P0170
the service manual lists these as the possible causes to that code
Volume air flow sensor output frequency Injector Fuel pressure Intake air leaks Engine coolant temperature sensor Intake air temperature sensor Barometric pressure sensor o2 sensor Exhaust manifold cracks |
its probly the o2 sensor cuz that was what fixed mine when i trew that code. if you havent changed it in a while or havent ever changed it then i would do so. bout 100 bucks max to change and it dosnt take that long to do it
