Cheap ways to upgrade
Hey every1 i drive a 96 RS the interior is ok could use alot work though and the exterior is pretty good as well but i low on cash and were wondering on cheap ways to upgrade on the car! I was later hoping to swap the front end of it to a 97-99 front end is that even possible? Also my left front turn signal keeps going out forcing the rear turn singal or light to flicker faster than the right what do i do to correct this? And one more thing I know it's alot of question s but im pretty much a noob at this so how do u remove the interior light i want to replace the bulb inside of it? Thanks aalot of help is need i wld appericate if any1 wld respond!!
RE: Cheap ways to upgrade
1. Upgrading an RS is very limited since your really not gonna see any power gain. Intake and exhaust are always the cheap and easy things to do. Other than that there really isnt much worth putting money into.
2. Yes you can swap the bumper to a 97-99 you just need the headlights from the newer year. Here is the writeup on that https://mitsubishiforum.com/m_131283/tm.htm 3. If the bulb keeps blowing then it must be a wiring issue. You have to trace the wiring and see if there is a loos connection or a bad ground somewhere that is causing them to blow. Also check the fuse for the lights and make sure they are in there and are the correct amp fuses for those locations. Also please use the search function as alot of these questions have been answered before |
