Clutch question
when i have my foot down on the clutch constantly over and over again, and waiting at lights and such, after awhile its get harder and harder to change gears, could it be something wrong with the clutch or is my exhaust too close to it, or something simple like a tranny fluid change or something? any suggestions?
RE: Clutch question
Flush out the crappy fluid... replace it. See if that makes a difference
RE: Clutch question
ORIGINAL: Sebba Flush out the crappy fluid... replace it. See if that makes a difference I had the same issue when I get stuck in traffic, after I changed the fluid, the shifting issue was gone. |
RE: Clutch question
also check for fluid leaks around the master and slave cylinder. if your leaking fluid then your clutch isnt gonna fully disengage
RE: Clutch question
If it was just dirty fluid I would think it would do it all the time, not just after a while..
But thats the cheapest and easiest thing to try ;) You know how to bleed it? Or you need help? |
RE: Clutch question
when was that last time ur fluid was changed?
RE: Clutch question
i don't know when the last time the fluid was changed i've only had it for almost a year now. and i don't know how to bleed it. if it's simular to breaks then i have an idea, but if it's not i don't know. how much is a tranny flush and to have it get new fluid?
RE: Clutch question
Dont worry about the tranny flush. Yes the clutch is similar to brakes
RE: Clutch question
You can use dot 4 or better brake fluid.. The bleeder valve is down on the left side underneath... When you push the clutch pedal down (Like the brake pedal) make sure it doesnt go all the way to the floor... Otherwise you will have to do it all over again... The tranny fluid is up on the right side by the firewall.. You can tell if the fluid needs to be flushed by how dirty it is in the container up there.. If it looks clean then thats not the problem..
RE: Clutch question
yea it sounds like a leak. my GST is doing the same thing and the fitting is leaking so im going to replace the slave cylinder and the line to be safe.
