Clutch sound
Wheni hit the gas and get up a few hundred RPMS the car make a grinding/rubbing sound out of the engine bay on what sounds to be like the passangers side im thinking its inpart due to a ****ty cluth (XTD) im also thinking a ACT would stop this, what else do you think?
1996 Eclipse 6-Botl Stage 3 6-Puck XTD sprung clutch GS_T |
RE: Clutch sound
I kinda need some input becuase its getting worse.
Do you think if the transmission mount are f'd up that it could be making this sound becuase all engine mounts are the new. What if the clutch was not put in just right? Anyhting |
RE: Clutch sound
does it only make the noise at low rpms or does it get louder as the rpms go up at all?
RE: Clutch sound
The sound starts up around 1900-2200 and it sounds to me like it stays the same and when i let off the gas even at like 4500 and let it chill at high rpms the sound stops. only when i accelerate and sometimes when i accelerate hard.
