Clutch TOo quick..
Old 05-29-2006, 11:21 PM
gstTurbo2011's Avatar
Default RE: Clutch TOo quick..
sry bout that
Old 05-29-2006, 11:29 PM
i just learned on the gsx this past week. I was doing the same thing as you so i started just letting it out real slow until the car started to move and then i gave it gas. Then i kept working at speeding up this process and im doing pretty good now
Old 05-29-2006, 11:39 PM
Sweet... and just to clarify.... the RPMs should never leave 3000 when your foot is on the clutch. If your foot is on the clutch and you are giving it gas you are burning up the clutch
Old 05-30-2006, 01:12 AM
TCossuto's Avatar
wow, so how many of you are 15?
You really should learn the proper way:
use no gas, slip the clutch up slowly, and launch like that till you get it right.
You want to bring the clutch up as you let teh gas down.
Old 05-30-2006, 03:25 AM
DSMTalonAWD51's Avatar
fastest way to get used to the car's clutch engagement is to start at a flat spot, dont even touch the gas pedal, and just let off the clutch slow enough so that it grabs on its own, once you get used to where it grabs, then u can use the gas an finess it to start off quicker
Old 05-30-2006, 10:59 AM
ORIGINAL: DSMTalonAWD51
exactly...thats what i had told paintball when he was trying. As long as you let it off really slow this will work. If it doesnt then maybe you have a bad clutch and that might be why your having a hard time learning
Old 05-30-2006, 07:15 PM
i did not know how to drive a standerd till i got my car lol i learned in 1 day because i had to i had been driving my mustang around befor that sadly it was a auto [sm=boohoo.gif] and it was nice too
Old 05-30-2006, 07:33 PM
k thanks..i'll try using just the clutch to get it going then add gas..i think i just need to keep practicing..i have to find the catching point..
Old 05-30-2006, 08:12 PM
btw thank you engineer!!!!!!!
Old 05-31-2006, 11:52 AM
ORIGINAL: paintballproam
no problem man. Hows that going actually
Quick Reply: Clutch TOo quick..
