Code P0125 Help
Ok so I had the check engine light turn on and I got it scanned and reset, it came on again it was P0125 - Inadequate collant temp for closed fuel circuit.(In other words the car is taking too long to reach operationg temp) I looked on obd-codes.com and it said that it is eaither a stuck thermostat or a bad coolant temp sensor. The gauge reads that the car is warmed up and the heater is definently hot so do you think that it is the sensor or the thermostat?
RE: Code P0125 Help
Sensor is my bet...
RE: Code P0125 Help
id start with the temp sensor
RE: Code P0125 Help
Isn't there a spec for ohming the sensor? You might as well replace the sensor, replace the thermostat and flush the coolant. How old is the coolant in the car?
RE: Code P0125 Help
the sensor only costs $22 so I am going to start with that. The coolant is about a year old.
| All times are GMT -5. The time now is 08:53 AM. |
