Coolant Bottle
i have a 97 spyder and my coolant bottle has a crack in it. it was sealed before but now it leaks again i tried the dealership but i cant seem to find the bottle anywhere. does anyone know here i can find a coolant bottle for my car??
RE: Coolant Bottle
dsmsource . com mitsubishigraveyard . com
RE: Coolant Bottle
thanks
RE: Coolant Bottle
You could use a simple fix like epoxy on that, or check the local junk yards
RE: Coolant Bottle
duct tape. jk epoxy should work
RE: Coolant Bottle
Gatorade bottle FTW.:D but for real check a junkyard. |
RE: Coolant Bottle
Its just plastic. I you go to autozone they have a bunch of different products for fixing it. There is a radiator repair kit that will seal it easily for now at least until you can find a replacement
RE: Coolant Bottle
How bout using some zip ties :Dhahaha
RE: Coolant Bottle
radiator leak won't fix the plastic, use waterweld, that stuff is the bomb, and my buddy used it on his coolant reservoir and its still holding it together to this day
RE: Coolant Bottle
Im not talking the liquid that you pour in. Im talking about the stuff that welds for plastic. But sometimes they call it a radiator repair kit. Its probably the same thing your talking about
| All times are GMT -5. The time now is 10:26 AM. |
