A couple of questions about...
1. My passenger door handle broke and I bought a new one. I have the entire door panel off, the screw out of the end of the door, and have it pried off somewhat. I broke the handle in half at this point. There is a bolt on the inside I can barely reach and I can't get the plug thing off where you put the key in the handle. Does anyone know an easier way? It looks like I am going to have to completely dismantle the door here. I don't know what to take off next... it seems like part of the inside metal part of the door will have to come off next... please help. 2. I was going to replace a blown speaker in that door. I measured but I guess I measured wrong because the 6.5" speaker won't fit (too small). Does anyone know what size will fit perfectly? This is a 98 GST Spyder... Thanks for the help! |
RE: A couple of questions about...
OK I did find this about the door handle. This isn't an easy job where it is located!
http://www.dsmtuners.com/forums/showthread.php?t=101589 I also found that the speakers are maybe 7"? I hope I can find an adapter... |
If you go through crutchfield they will send you all the adapters you need including wiring adapters so everything plugs right in. I got my fronts from them and am very happy with them.
