cutting out
Yeah i noticed while turning right at a stop sign today, that if i try to go around it kind of fast, it cuts out for a split second, then goes back to normal....wtf?
RE: cutting out
what cuts out....your engine?
RE: cutting out
i have the same problem once in a while, but it's when i turn left. if i'm in a parking lot or something and i turn the wheel ALL THE WAY very hard the engine will stutter and cut out for a second until i turn the wheel just a little bit back toward the right....
RE: cutting out
might have something to do with the power steering pump taking the power away or something.
RE: cutting out
what engineer said, I second that. IMO
RE: cutting out
definately power steering
RE: cutting out
Defenatly pwer steering. Just dont give it full lock and you will be ok. Either that or get a better alt
RE: cutting out
I am pretty sure that is normal for it to cut out like that, I think there is a switch for the p/s pump preventing the car from stalling from hard turns.
RE: cutting out
ORIGINAL: Sebba Defenatly pwer steering. Just dont give it full lock and you will be ok. Either that or get a better alt |
RE: cutting out
nothing... but if it takes alot of the power. The stock eclipse alt is known to be crap.
