Do I need a camber kit?
Old Sep 30, 2004 | 06:50 PM
darkman0127's Avatar
Default Do I need a camber kit?
On a 1G do I need to worry about a camber kit if I lower it 3"? I was talking to a guy about buying his coilovers off his 1G and he said the suspension is stiff enough that it does not need a camber kit. Is this true or false? Thanks.
Old Oct 1, 2004 | 01:37 PM
SpyderGS's Avatar
Default RE: Do I need a camber kit?
You probably don't, not with the stock wheels anyway. If the guy has them on his eclipse still, go look at his tires. If there's un-equal wear on the tread or if the tire is cutting or chopping, then be sure to ask him why. Also, check with the manufacturer of the coil-overs. On their website, it will usually tell you if you need any camber adjustment.
Old Oct 4, 2004 | 09:12 AM
Ok, cool. Now..what about "balancing" the car after I put the coilovers on it? Can I do this or is it better left to pros? Thanks for the help!
bestwiseguy
Oct 31, 2007 09:49 PM
DixonsGst
Jun 12, 2006 04:34 PM
bluballz07
Apr 1, 2006 08:28 PM
bluballz07
DixonsGst
Dec 11, 2005 04:42 AM
