Does your eclipse burn oil?
Old 02-25-2005, 05:09 PM
coliphage's Avatar
Default RE: Does your eclipse burn oil?
ORIGINAL: Tmann26
I haven't checked my oil since the last change 9,000 miles ago, LOL.
that's no good for you car, man.
have oil regurlarly changed is the cheapest yet most effective way to keep the engine running long...
Old 02-25-2005, 06:01 PM
if you have oil on the plugs, you have a bad head gasket or bad vavle seals. changing your vavle cover gasket will not help this, do a compression test go from there. burning oil is not common in eclipse, its common in cars that people dont maintain properly. or in cars running high horse power because that puts stress on a motor, so it has to have them changed more often.
Old 02-26-2005, 11:09 AM
Well, to be honest, I'm not worried too much, well, I wasn't... I just turned 50k, so I'm gonna start doing regular checks. I also don't have any smoke coming from the exhaust, or any puddles where I park the car, so I'm willing to bet all 4.8 quarts of oil are still in it, lol.
ORIGINAL: coliphage
ORIGINAL: Tmann26
Old 02-26-2005, 07:04 PM
ORIGINAL: coliphage
ORIGINAL: LatinSpeed
The oil was on the tips of the plugs. and the smoke was from the exaust, like a thick bluish smoke, and I know thats not normal. Any ideas?
souds like inner oil leakage. might be blown head cover gasket . oil finds its way through the gasket into the cylinder.
that why you have oil on the plug tip and blue smoke from the pipe. need quite some $$$ to repair.
If you do it your self worst case its might be the head. max amount i have seen from dealer for a head is 500 bucks. that is everthing gaskets and all.
Old 02-27-2005, 02:33 AM
Get 435 thats actually good news. I was more worried about the cost for the parts than the labor, I probably cant do it myself, but I can get help without paying an outrageous amount. Yeah, man Im sure I could do a better job with the maintenance, though I havent gone 9,000 miles without doing an oil change.
Old 02-27-2005, 03:01 AM
i have a 99 OZ racing edition n/t and ive blown a head gasket once at a car show but no other real problems and havent ever noticed any oil burning so far, it has 92k miles.
Old 05-14-2018, 03:55 PM
Chris Sides's Avatar
Default Which gasket are you speaking of?
Originally Posted by ceeceeforlife
mine was burning old when i got it. but they replaced the gasket,and now is fine.btw,my eclipse is 96 rs,nt.
I have a 97 rs n/t and it seems to burn oil and smoke only while in idle. Which gaskets should I look at replacing?
marollocd
11-13-2008 04:59 AM
oldschoolturbo
07-09-2007 10:53 AM
tidus10
02-02-2006 03:04 PM
slow420a
01-23-2006 04:40 PM
Quick Reply: Does your eclipse burn oil?
