doors are leaking water??
Hey i have a 96 rs and the doors leak water whenever it rains and i'm going to have the door seals replaced but before i do that i was wondering if their might be any other possibilities as to how the water is getting through....any help would be great thanks.
Chris
Chris
RE: doors are leaking water??
well when he said door seals i assumed that he meant all of the seals around the door... and if it was the lower door seals then he probably wouldnt be getting a whole lotta water inside cause it's got the lip of the door jam to stop it... so i'm assuming its the seals above the window that hes talkin about
i didn't know that there were drains for the doors i just thought the seals kept the water out but the leak is around the side mirrors on both sides of the car....the worst is definately the passenger side when it rains i get a little puddle on the passenger floor.....the only thing that i'm afraid of is the floor rusting out....but what about this drain for the doors??
On the bottom of your door there are a couple little holes that drain the water out that gets in the door. The water gets in fron the outside seal where the rubber meets the window. But that is not your problem. More than likely the rubber seal on your door is just old and worn out. It sat outside in rain and snow, and all the other elements. Once you replace them it should fix your problem. If you dont replace them then yea your floor will rust out and you will have to drive your car like the flintstones.
owensth
08-10-2010 02:43 PM
