-   -   Drive without a Balance Shaft belt??? (https://mitsubishiforum.com/forum/2nd-generation-63/drive-without-balance-shaft-belt-15811/)
motoxxx87 Mar 14, 2010 02:28 PM
Right i know that but on the cam gears marks were are the ones that they are spouse to line up with? are the on the head???
dsm1990gsx Mar 14, 2010 04:25 PM
Did you read the link I gave you abt the timing belt procedure?
JSHERRON Jun 15, 2022 01:38 PM
Originally Posted by motoxxx87 (Post 257046)
Hi i have a 97 Talon TSi turbo i was siting at a light and my car just died. Got out and looked and my balance shaft belt broke, going into my timing belt i believe because when i pulled the cover on the timing the belt was still on but ripped up a little. I was wondering if there any way to tell if i bent a valve with out pulling the head? And is i worth just trying to put a new belts on?
To check the valves, all you do is pull the valve cover off, pull the rocker shafts off to get the pressure off all the valves. Then look at the valve stems. If they're all the same height you're good. If you see one or more that are short, start pulling the head. You have bent valves.
If you don't see bent valves, put your belt back on and then do a compression test to make sure you didn't bust a piston instead.
