-   -   Eclipse Spark Plugs (https://mitsubishiforum.com/forum/2nd-generation-63/eclipse-spark-plugs-20637/)
dorian7 Jul 20, 2007 08:24 PM
Eclipse Spark Plugs
I alredy posted this in internal lounge but it didn't get any attention there so I figured I would give it a shot here....
So I was reading the post by sparkplugs.com (in the internal lounge) and I noticed that under multi-ground plugs, such as the OEM plugs in my 98 GSX, they said that some engines are disgined to use multi-ground plugs. Is that the case with the GSX?
tjbiker031 Jul 20, 2007 08:31 PM
RE: Eclipse Spark Plugs
you know i would just use good ole' NGK plugs and wires....i would forget about everything else
Sebba Jul 20, 2007 08:51 PM
I dont think the GSX uses multi ground plugs from stock.
NGK FTW
dorian7 Jul 20, 2007 09:10 PM
Well that is what I pulled out of it and that is what the auto parts stores said is OEM.
dorian7 Jul 20, 2007 09:42 PM
http://ngk.com/results_app.asp?AAIA=1316593
silvercoupe97 Jul 21, 2007 03:54 AM
This is what you need...
http://ngk.carshopinc.com/product_in...id/40845/BP6ES
BP7ES is what you need if you need a one step colder plug.
Nothing fancy because more than half the time they don't work well with the 4g63, modded or even stock.
This...
http://ngk.com/glossaryImages/85.jpg
..not this...
http://ngk.com/glossaryImages/84.jpg
silvercoupe97 Jul 21, 2007 03:58 AM
BTW, the 6ES and 7ES have been used by all years of the Eclipse/Talon/Laser and is proven to work very well. The next ignition proven upgradeare COPs. No fancy platnums or iridiums, just the traditional plugs.
Sebba Jul 21, 2007 05:08 AM
So why in the hell is it saying thats the OEM?
silvercoupe97 Jul 21, 2007 05:17 AM
Couldn't tell you. Maybe they did use these plugs from the factory, I don't know. These cars are too old, lol. There aren't enough "original" owners to ask.
Honestly, OP, you can try them out if you like, but....I still say, "don't reinvent the wheel" ;)
Sebba Jul 21, 2007 05:21 AM
Damn strait! Perfect way of putting it
