Engine Build
Hey, here's a list of potential stuff done to an engine... how much do you think all of this would cost to get professionally done? and how much power to you think this engine could hold??
6-Bolt 4G63[/b]
[/b]
[/b]
HEAD[/b]
-Resurfaced
-New stainless valves cut with a radial valve job
-New stock valve springs
-Roller rockers
-Ported/polished all the way through intake and exhaust sides
BOTTOM END[/b]
-Knife edged crank, balance shafts removed
-Bored .40 over
-Eagle rods floated off crank onto piston heads
-JE pistons
-Ported/polished
-Blueprinted
-Water jackets and oil channels cleaned
-6-layered and reinforced head-gasket
-New flywheel
-New clutch
-Fuel pressure regulator
-GM MAFT and MAF translator
-450 Injectors
6-Bolt 4G63[/b]
[/b]
[/b]
HEAD[/b]
-Resurfaced
-Roller rockers
BOTTOM END[/b]
-Bored .40 over
-JE pistons
-Ported/polished
-Blueprinted
-New flywheel
-New clutch
-450 Injectors
well, i'll be upgrading the injectors.....oooooooooook so this is the motor+ that im going to be buying off a guy that i'm currently "working" with... so far this is the parts list that he's given me... There's more to come, im just wondering how much you think all this is worth? he has all of the receipts and it was all professionally done, no hack-job sorta deal... i should have the rest of the list in the next couple of days...
by the way he's runnin a 20g turbo, the whole motor has less the 5,000 miles on it, mostly highway miles, hasnt taken it to the track since it was rebuilt, before it was he said he ran a 12.9
ew MAFt. Id get rid of that. But you really need the whole list. Is it coming with the entire turbo kit as well. Cuz if this is "just" the engine then its a rip off. Because you could get a 6-bolt fairly cheap. And build it up for less than that easily. I think JLH is in the right ballpark with $2500.
