-   -   engine componet locations. (https://mitsubishiforum.com/forum/2nd-generation-63/engine-componet-locations-3424/)
ecp_drv Feb 20, 2005 07:07 PM
I just had my engine check light came up. I did a test and got the diagnostic codes. But I cant figure out where they pieces are located so I can fix it.
They are:
Airflow Sensor, Idle Air Control (IAC), and Traction Control (TC) vent valve solenoid.
where are they located? Please help
customizedrides Feb 20, 2005 09:40 PM
RE: engine componet locations.
Your air flow sensor is usually right after the throttle plate. There should be a throttle position sensor and then the air flow. There might be a diagram on the hood, just look for the Mass Airflow Sensor. Traction control I would think would be around the tires like an ABS sensor but that's just a guess. Idle air control should be somewhere not far off from the intake. You can also pick up a Haynes manual for it and those are great.
