Engine Hopping
Engine Hopping
WhenI left off the clutch a lil and give it a lil gas like im inching forward,I hear this pounding sound like im rinding on bear rims and they have flat spots and im trying to do a burnout. It only happens in first gear.Umm you ever rev you car up and dropped it into gear and heara loud pound its like that be faster. I check the motor mount my front mount bolt fell out replaced itand I just changed my trans mount, changed the master cylinder cause it was leakin. still happens. I can't get it to too it all the time I noticed it happen often in stop and go traffic where im constanly hit and lettin off the clutch, also when the ground is wet Ill get it.I at a point where Im jerkin the carbecause im lettin off the clutch too fast or burnin up the clutch, justso it won't happen again. I tried have them look at it at work 3 techs couldn't get her to act up. There prognosis is that I can't drive a standard. I'm thinkin its something with the crankshaft. IDK
RE: Engine Hopping
Thats what I thought at first so I gave it gas one time and it just speed up the noise, the when I let off I hears something like the clutch/flywheel lwas still spinng like they're warpedIDF'n Know.
RE: Engine Hopping
Yes zeeer!I sound crazy huh? It rarely happens but I noticedit happen more so whenin stop andgo traffic, lights, stop signs, parking lot.I can get sometimes when other ppl are in the car with me but for them to do it they can't, my mom is always stallin the car (she' forgets to downshift and tries to take off in high gears), oneofmy other friend is always burning up my clutch (she'll slowly start to let off around 2,500 rpms[:@]and keep down on the gas paddle)
RE: Engine Hopping
why dont you get a tech toride in the car with you.....most will if they arnt busy....and recreate the problem in the parking lot (cuz that sounds like where it usually happens) and do some stop and go driving?
