-   -   evap leak (https://mitsubishiforum.com/forum/2nd-generation-63/evap-leak-36790/)
squishyamocito2007 Aug 18, 2010 07:04 PM
evap leak
i took my car to get it smogged and it failed because i have a leak in my evap system... i was told it could be a bad gas cap, egr valve, charcoal canister,bad hoses or gaskets but i dont know how to find the leak... how will i go about finding it? keep in mind i have tools but not specialty tools like vacuum pumps or gauges.
Phil424 Aug 19, 2010 02:36 AM
I had the same problem with my eclipse, it turned out I had a large hole in my filler neck. I discovered it when I first got the car and gassed up at the pump, I had gas shooting out of the hole when the fuel reached the top. I had to order a new filler neck and replace it. Talk about weird.
KaiserEclipse Aug 25, 2010 03:23 PM
check all your hoses and gaskets for anything leaking first (always check for leaks) and as far as the egr or charcoal canister, im pretty sure the car would throw a code for either of those, if nothing else check for rust holes in your exhaust.
