-   -   fendors and front bumper (https://mitsubishiforum.com/forum/2nd-generation-63/fendors-frnt-bumper-1067/)
T76 turbo Apr 30, 2004 12:25 AM
hey i just want to know if a 90-91 eclipse's front fendors and front bumper would fit no problem on a eagle talon from same year. i need those parts and i would be able to get them free off a 90 gs .
91eclipse Apr 30, 2004 04:42 PM
um...i know those cars have interchangable parts.....i am guessing you can make it work. i cant really say 100% if the they will bolt straight up to the talon. You can make it work.
SpyderGS May 1, 2004 04:04 AM
The 89-90 used pop-up headlights, right? As long as they used the same headlight configuration as you, the fenders and front bumper cover will be interchangeable. If you haved the fixed headlights, the earlier bumpers will need to be cut some to fit. The fenders may not fit at all though. Once again, it all just depends on the headlight configuration.
chrisscadman May 25, 2012 12:48 PM
You can replace these bumpers but you have to work with the fittings because you can't simply take it off the other car and put it on yours. :D
