fiav block off
Old Jan 21, 2008 | 11:36 AM
oh_what_up's Avatar
Default fiav block off
hey guys. I have a 1g throttle body on my 2g and have been experiencing high idle (2000rpm). I already have re-routed my coolant lines so they don't circulate through the fiav, but i know it can still be a boost leak point whether those lines are hooked up or not. They do sell a plate that retains the iac, but since the iac housing is a part of the fiav i would imagine that you have to put the block off plate in between the fiav and the throttle body (Unlike the complete block off plate where you just completely get rid of the lower portion of the fiav). My question is; if you are sandwiching the plate in between, how does it seal? Is there a gasket for the fiav where i can just buy two when i install the plate? Or would i just use hi-temp RTV? Thanks guys. As always I appreciate your help and expertise.
dorian7
Jan 22, 2008 06:09 PM
N/Teclipse
Dec 5, 2006 02:06 PM
ttenn
Jun 10, 2006 01:45 AM
92_laser
Nov 10, 2005 06:47 PM
mitsu4x4nuts
Oct 16, 2005 04:08 PM
