fuel filter question
RE: fuel filter question
you're gonna need a 10mm wrench and a 14mm and 19mm flare wrench. It's a PITA to get to imo, but you need to remove the Bat, tray, and support. then loosen the line from the filter to rail. next remove the line from the tank.
desrever si noitallatsni.
I'm not doing that whole mess again. when I upgrade my fuel lines to SS, I'm gonna disconnect the tank line and cut the line under the filter. then just feed the flexible SS line up and install the new filter. HAH! DSM.
