gasket set
Old Apr 10, 2006 | 04:55 PM
bagz's Avatar
Default gasket set
i got a head gasket set and i need to know what goes on the head? (like the valve seals or whatever) and what tools do i need to do it?
Old Apr 10, 2006 | 05:10 PM
Sanguinius's Avatar
Default RE: gasket set
What do you mean you need to know what goes on the head? As in what is attached to the head? Or what gaskets are used on the head?
Old Apr 10, 2006 | 05:11 PM
bagz's Avatar
lol yea what gaskets, ill put a pic of what i got . hold on a minute
Old Apr 10, 2006 | 05:12 PM
bagz's Avatar
Old Apr 10, 2006 | 06:48 PM
bagz's Avatar
ANYONE???
Old Apr 11, 2006 | 10:50 AM
93eclipsegsx's Avatar
in the picture,
1. the top one is the head gasket, it goes in between the block and the head.
2. below that there is two rubber rings, those go on the end of the camshafts. to put those on you have to unbolt the last cap so you can get them off. to put them on just put a light coat of oil on them and kinda screw them on so they dont fold over.
3. the skinny rubber seal, do to the underside of the valve cover. and the 4 other rubber seals cover the skark plug hole on the underside of the valve cover.
4. in betweenthe valve cover gasket and the camshaft gasket there is a piece or rubber that looks like a half moon, that goes on the same side as the camshaft sensor, but on the orther cam.
5. the 4th line down is the intake manifold gasket and the one below that is the exhaust gasket.
if you have any other questions just let us know.
Old Apr 11, 2006 | 04:46 PM
bagz's Avatar
what do i need to change the valve stem seals?
Old Apr 11, 2006 | 08:13 PM
what are you actually doing, did u bend valves or something?
Old Apr 11, 2006 | 08:35 PM
bagz's Avatar
ok i bought the car with bent valves. he included an extra head that i have to put on. i bought a gasket set and im trying to replace the valve stem seals. also i just bought the tool (valve spring compressor) and i cant figure out how it goes on the spring. theres not enough room . ...??????????????
Old Apr 11, 2006 | 09:43 PM
get435's Avatar
bent valves dude the best thing to do is take the head and all your parts to a machinest and have them do the head it will also ned a magnaflux which is a dye it is diped into that uncovers cracks in the head that are not visable to the naked eye for all you know it could have a cracked head and all this work is for nothing.
