Greddy Recirculation Fitting
Greddy sells the recirculation fittings for the type rs bov.............which size fitting do i need to buy for it to work with the stock intake and bov pipe?????
RE: Greddy Recirculation Fitting
just check the pipe that is there and get the size of the dump tube. That will tell you.
Can't you use your old tube that recirculated? I did that and it seems to be working just fine. Or you can take take the old pipe in to a part store and measure how long you need it to be. A low pressure rad hose can work
