Ground Wire System
Old Feb 15, 2005 | 02:49 AM
silverspyder's Avatar
Default Ground Wire System
Do earth ground wire systems really work?
Old Feb 15, 2005 | 02:18 PM
Eclipsel3oy99's Avatar
Default RE: Ground Wire System
ive heard they do. if you think about it, it does make since. cuz with a better ground everything electrical would work that much better and with a better ground you can prob achieve a hotter spark. so i think it could b worth it.
Old Feb 15, 2005 | 02:32 PM
outlancer's Avatar
it only works if you have a grounding poblem already, the benefits dont outweigh the cost. my friend made his own for what he spent like $25 then do the benefits outweigh the cost but if it is a high dollar kit not really worth it.
Old Feb 15, 2005 | 03:54 PM
1398spdr's Avatar
yes, they do work, mine works great, and it took like an hour to make it and another hour to install, well worth the time and 20$ i spent............ even if you dont have a grounding problem, they help the electronics get a more constant supply of electricity, helping them perform their duties at a better than average level...........
Old Feb 17, 2005 | 12:11 AM
What gauge wire is best for this and how hard is it to install?
Old Feb 17, 2005 | 08:59 PM
1398spdr's Avatar
4 is the best, i used 6 cause i couldnt find a 4 guage to buy in one 25 foot section, and the 5 ft sections cost like 9 bucks a pop......... with the 6 ft u can use jumper cables, just cut em to length, solder and crimp the connections, and hook it up, simple..........
Old Feb 18, 2005 | 09:59 AM
get435's Avatar
auto shop will have the four gage wire you can use and its cheep!
Old Oct 6, 2006 | 01:34 AM
darkstar752's Avatar
does anyone have info on good grounding positions for a do-it-yourself kit? i have a 1996 eclipse.
Old Oct 6, 2006 | 10:21 AM
RCJr9186's Avatar
i bought the greddy grounding kit, hooked it up to my valve cover, throttle body, intake mani, block, head, and trani and it works beautifuly. however i had to run a wire from the grounding kit through my car b/c i relocated the battery... but you prolly won't have to.
DylanRobles
Mar 8, 2012 02:35 PM
expositor
Jul 23, 2006 04:34 PM
dirtwagon
Feb 19, 2006 10:21 PM
faded2
Jan 19, 2006 08:43 AM
blamesociety
Dec 16, 2005 09:14 PM
