GST questions
ok well i have been told that 95-96 crankwalk more offten tehn 97-99... why is that? just cause the age or is there something different to there bearing setup, or what not? If so what would i do to the engine when rebuilding it so its not as easy, or would i have to buy a 97-99 block?
RE: GST questions
ORIGINAL: ridingDSM0201 ok well i have been told that 95-96 crankwalk more offten tehn 97-99... why is that? just cause the age or is there something different to there bearing setup, or what not? If so what would i do to the engine when rebuilding it so its not as easy, or would i have to buy a 97-99 block? 2) Don't worry about crankwalk, jut replace the bottom with a 1G bottom and be done with it or replace the entire 2G motor with a 1G motor. Why? Because they have a stronger crank system. 3) Run the 2GA motor until or if the motor walks, then get a 1G bottom or 1g motor. |
RE: GST questions
I wrote a whole thing on this and the damn post problem happend again.
Either way, to reitterate what Silvercoupe said, don't over estimate it, even Supras can crankwalk. |
RE: GST questions
yeah i wrote in on it too and it screwed up on me as well lol.
RE: GST questions
I forgot about the issue of posting and got lucky somehow! I would have been pissed too...again, lol.
RE: GST questions
yes supras car but not that often, the 2G is alot ALOT more common to have bottom end issues than even a 6 spd supra (which also can crankwalk given the wrong crankpulley clutch flywheel combos)
RE: GST questions
its nothing to get your self worked up over and start pulling your engine and swapping motors just yet, just have a plan ready if it ever does
RE: GST questions
i bought a 6-bolt to build up, but hopefully my 7 won't walk. The only reason i bought a 6 bolt was so that when i spend a bunch of money on an engine, hopefully it won't die cause of something stupid.
RE: GST questions
yea man thats something i was gonna suggest, you can buy a 1g block or motor and build it up. then that way if you're motor does blow you'll have a built one ready to pop back in. but crankwalk isnt as normal as people say it is really.
RE: GST questions
yeah i'm not worried about it, but hey the block was 75 so i figured might as well do it right. just play it safe
