GST Turbo problem-no boost
Bros, I have a 98 GST Spyder. Today I started having this problem of no boost building. The car is stock, and the needle of my stock boost guage goes only like halfway up as opposed to the normal upper position where the "+" sign is. Of course performance is seriously hampered, as you can imagine! Any ideas? Suggestions? Is my turbo on it's way out?
Thanks in advance?
Thanks in advance?
If you're noticing performance issues I'd say your turbo is already out to lunch... Probably in need of a rebuild... (The turbo not the engine)... What do the rest of you guys think?
when you first said it wasnt building boost frst thing tha came to mind was nylon line to the fac boost gauge has stretched n caused a miss read but if your noticen a serious perfromance decrease then i would think its your turbo also. how else has the cars performance been effected ?
You know, I haven't heard anything that sounds like the death......whatever sound it was yet![Smile](https://mitsubishiforum.com/forum/images/smilies/smile.gif)
Domestickkilla, about the way the performance is hamperred, well, it just doesn't pull as hard at all, especially on 2nd, 3rd and up. On first it seems to be still about normal, eventhough it's noticably slower.
You huys think it may be some kind of pressure or boost leak. I friend of mine suggested that, makes sense to me. What you think?
Thanks
Thanks
Is your turbo spoolin up all the way.or does it sound like something is in the turbo,or turbine,something from the road or whatever might be stuck in it.Thats what happened to my buddys turbo'd Civic,by the way it has 347 whp.
ORIGINAL: GST WNB
Yeah check and see if it's spinning freely. Also check all hose connections for a possible leak. And again also check your wastegate as well as the turbo itself for fre movement and shaftplay.
I had a boost leak from a crack in my BOV and the gauge showed normal boost PSI but the car felt like it was only runing like 10 rather than 19 and it was a dog I poped the hood had touch the BOV and when I moved it a surtain way you could here it hissing out air.
