guesstimate
I want my gst spyder to run a low thirteen pass in the 1/4 and i want this to be consistent pass after pass but the bottom end has 86,000 on it the head was just rebuilt due to a bad timing belt and Stage 1 valves , new head gasket ,plugs wires, tensioners balance shaft belt .mods are listed below pwr steering and alt belt and now mods listed on sig . what ive done ihave done right .I know i could cut out ac an pwr steering but its nice to have that stuff . now I know i can turn up my boost a little bit more on my 16g if i run a higher octane but wouldn't it be cheaper to up grade the injectors to handel the increased fuel or will that reQuire a reflash of my cpu i thought nos but that **** can be lethal .especially to a high mile age engine . i guess the bottom end needs rebuilt but i want to beat my buddies v6 camaro i know my cars fast but anymore things i could do to lower my times like bring gas in cans use my 15inch stock wheels any other ideals to drop quick weight or add a few horses before i smoke this guy and according to the 1/4 mile calculator i need about 315 hp to get the job done ..unfortunetly i don't have a dyno meter in my backyard so i don't know how many horses would you think i should be around?
well if you wanted to go alittle smaller and alittle cheaper you can get EVO stock injectors which i think are like 660cc or something. But i think its better to have alittle bigger than required. I think PTE has decent injectors for the price
http://www.extremepsi.com/store/cust...cat=628&page=1
I dont remember if you need clips or not. But if you want to save money you can definetly go with stock EVO injectors
760's is way too big for SAFC.
