guzziling sound
I get a guzziling sound when I let out the clutch and put it on neutral does anyone else have a similar problem?
How to fix? |
RE: guzziling sound
I think I know what you're talking about...It almost sounds like something is grinding, or boiling...I can't put my finger on it, but when I let up off the gas, and the clutch, I get that wierd noise....hmmm. Anyone?
RE: guzziling sound
I have the same probelm and I know 2 things that it might be. One could be that the syncro's are not blocking the gears from slightly rubbing together or that the bearing right were the Shaft enters the trans. is bad. But there are other things it could be. Now this is if your refering to a grinding noise. Mine started right after my clutch was shreaded to crap. I just plan on replacing the trans.
RE: guzziling sound
u got me.............sounds like what my aunts trctor does
