Head is about to come off.. but need some HELP!
#52
RE: Head is about to come off.. but need some HELP!
that happened a month or soago, i got lucky and it never jumped time. its juat an example to why evrything should be replaced. just like the balance shaft belt that loves to get tangled in the timing belt and make a mess
[IMG]local://upfiles/10240/2FA0B55892A54EF8AD5A3E3345BD5DBA.jpg[/IMG]
#54
Hey guys is this it:
camshaft belt idler, camshaft belt tensioner, balance shaft tensioner, balance shaft belt, water pump, water pump gaskets, & Head Gasket set (pretty much includes all gaskets when doing the head gasket and includes the head bolts) and of course the Timing belt.
Is this all I need to install the head gasket and timing belt?
#57
Well, if I were to slightly move the cam (because it is not in line correctly, it is slightly off)would that fix it? Before I took off the timing belt they were aligned perfectly. But it slightly moved (it must have...)
