Head Gaskets
Old Jan 26, 2007 | 06:10 PM
50ul }{4ck3r's Avatar
Default Head Gaskets
i wanna know what the best head gasket i can get....and were
when i drive and let off the gas at high rpm's.....my Exhaust sounds like a fart fest
it never sounded like that when i got it...plus would my Air flow converter cause that
Old Jan 26, 2007 | 06:27 PM
RCJr9186's Avatar
Default RE: Head Gaskets
if it's just backfire b/c of not a lot of backpressure that not a bad thing ( look at srt-4's).... if you are completely convinced thatit'sthe head gasket, best one on the market is Cometic, i get all my parts from CIMotorsports.net but you can find them many other places.
Old Jan 26, 2007 | 07:38 PM
maybe you have an exhaust leak somewhere.
Old Jan 26, 2007 | 07:48 PM
Nubiebubie_GSX's Avatar
My exhaust manifold is warped and leaks and causes that noise also.
Old Jan 26, 2007 | 09:45 PM
silvercoupe97's Avatar
ORIGINAL: RCJr9186
Cometic...yup, and don't forget to get ARP head studs since you're already there...hell, just build it up, lol. I keeeed.
I'm going with an exhaust leak too. You would be blowing out smoke from the exhaust if your head gasket was "bad". Check your flexpipe, bolts that connect the sections, cat...just check the entire exhaust tract for tell tale signs of black soot escaping. I know I have an exhaust leak (albeit a tiny one) right at the flexpipe because it has scraped a few speed bumps out here.
victim619
Aug 29, 2008 07:03 PM
atown420
Nov 6, 2007 11:52 AM
vess1
Feb 12, 2007 04:16 PM
DaveD
Jan 2, 2007 05:44 PM
abrywc
May 23, 2006 02:49 PM
