help i have a couple questions
Ya i was wondering 95 eclipse gst does that dosnt have the infinity sound right? well because i jsut boutgh my eclipse and stored it after i test drove it.
I was looking around in it and found a power cord and the whole nine yards pluis the power locks arent working and i heard a lot of other things were connected to that infinity ****? well i started takijng out the power cable and said hell with it its to dam cold up here in michigan (no heated garage):( and also the air bag is falling apart the interior piece is falling off of the metal is there a way to take that off with out anything happening? thats it for know so any help would be appreciated thanks shaun |
RE: help i have a couple questions
also the power locks
make a noise but dont work so i dont know what the problem is |
Well you'll know if you have the infinity sustem if the stock radio is still in there and it says infinity on it. If it was taken out and there is an aftermarket simply check behind it for a amp interface module or under the passenger seat for a amp. You could always call the dealer as well. As for the other problems....What's the power cord for>Your windows should have nothing to do with the radio. If you push the botton and it makes noise but doesn't move either sometihng is jamming it or the motor is broke. I would not touch the air bag without manufacturer directions on how to remove it. Most vehicles if you unplug the harness the bag will deploy. That could cause serious damage to you and your car. Also if the bag goes off the car is considered totaled and good luck trying to sell it. You have to be a bit more specific about exactly what everything is doing to get some better help. Like I don't get what you're saying with the door issue. It sounds like the locks work when you push the keylesss, but nothing happens? If this is the case someone probably did work on the doors and broke the actuators for the locks. Hope that helps some, and it's balls cold up here in VT too.
