Help! No Spark... Replaced PCM, Cam Sen, Crank Sen, Coil pak
Old Jan 3, 2006 | 03:31 AM
oops129's Avatar
Default Help! No Spark... Replaced PCM, Cam Sen, Crank Sen, Coil pak
my car has been in the garage for over a week now.... it will start up but then after about a minute it will die. after it dies, i get no spark.... i have now replaced the PCM, cam sensor, crank sensor, and a new coil pak. i have run through the wiring diagrams tested the relays and it does the exact same thing every time.....
any other suggestions??
thanks guys!
Old Jan 3, 2006 | 10:15 AM
RCJr9186's Avatar
Default RE: Help! No Spark... Replaced PCM, Cam Sen, Crank Sen, Coil pak
sometimes it's the simplest things... you have checkd the plugs and wires right?
Old Jan 3, 2006 | 12:03 PM
Sanguinius's Avatar
If you're getting no spark why did you replace the PCM? Look into the ECU. PCM is Powertrain Control Module. ECU Is Engine Control Unit. Also like he said check plugs and wires.
Old Jan 3, 2006 | 02:12 PM
get435's Avatar
Reason the pcm is a routing station for the whole harness it all routes through it.
Old Jan 3, 2006 | 08:12 PM
Sanguinius's Avatar
Oh I thought the ECU was what served as a routing station.
Old Jan 4, 2006 | 04:38 AM
Daithi's Avatar
Are you sure it gets no spark, because what your saying sounds more to me like a fuel delivery issue. Have you checked the fuel system at all? Cause if you've tested all the relays and replaced most of the likely problems and you still have the same issue then fuel would be the next place to look. Good places to start would be the fuel filter (if it hasn't been changed it could be clogging up and cutting off the flow) and the fuel pump relay.
Drivability problems are a bitch man, and they take a lot of time and patience to track down. Good luck.
davidsdlck
Dec 22, 2020 06:51 PM
wannakracka
Dec 2, 2009 03:09 AM
claytonkobe
Aug 24, 2007 08:27 PM
fireeatn1
Jun 2, 2007 06:00 PM
xslim69
Jan 20, 2007 10:41 PM
