High Temp at Idle
<FONT face="Arial, Helvetica, sans-serif" color=black size=3>Low temp at normal speeds - High Temp at Idle.</FONT></P> <FONT face=Arial size=3>Coolant, hoses, and Thermostat have all been changed yet problem persists. How do I diagnose further?</FONT></P> |
High Temp at Idle
<FONT size=3>By "Low Temp", I mean "Normal"</FONT></P> |
High Temp at Idle
I was having that same problem with my truck. It was my thermostat. I dont know much about imports but Im guessing it should have the same thing. sorryif im not much help but its just a guess.
High Temp at Idle
<IMG src=smileys/smiley19.gif border="0">Dude, check to see if your cooling fan for radiator is coming on at idle when fully warmed up.I have to believe that either your fan motor is not working or switch that tells it to come on is bad. The reason you don't overheat at normal cruising is air flow into radiator while you're moving is usually sufficient to keep things cool. Hope this helps, Randy
