How do you make a 1.8 perform ?
How much are you looking to spend? I'd just swap engines for one with a turbo. A 4G63 turbo engine would be nice? I don't think you can do much with a 1.8 liter. Maybe just an intake exhaust and headers, but that won't be that noticable in acceleration and power.
I really like the 2.0 Turbo (common sense) idea.
We have 2 different "all foreign" auto parts wreckers in the area and I'll bet something whole might be available.
Question here (?) would a 2.0 Turbo hook right up to the existing 5 speed transaxle ?
DT
DT
A friend of mine suggested that I disconnect the output line of the air conditioner compressor and then run it into the throttle air intake.
That way when I need a supercharged merge or else some puss in a Neon threatens to swoosh by I can press the little "snowflake" button and get some immediate boost!
My only question here is : Whenever I press the atomic supercharger boost snowflake button -would the road become blurry like I'm going into hyperspace like it did on "The Fast and the Furious" ? [:-]DT
Ok, if you rout your AC output into ur intake, you will probablly get negative boost. Everyone knows AC takes away alot of HP, and the forced induction that you will be putting into your intake with the AC will most likley not even be enough to compensate for the loss of horses from using the AC in the first place. Basically...dont do it your wasting your time.
And to answer your question, Dont go out and buy a new engine. First of all is your Talon in good enough condition to put money into in the first place? If yes, then dont drop a crappy junkyard engine in that may or may not have unseen problems that would set you back even more money. First of all you can buy a new car. Your other opion (in my opinion) is to throw on a cold air intake, cat-back exaust, headers, PERFORMANCE CAMS, cam gears, good spark plugs and wires, a performance distributor, performance clutch and flywheel, etc. All of this stuff will give you plentty of horse power. And i know all of you guys say "go buy a new engine", but its not that easy, and it will be worth the extra money to do all of what i just said. If you drop a used engine in, you will have a hard install first of all, second there are a number of small things that can go wrong with it, and third if there is something wrong trouble shooting will be hell, and if your lucky enough to find the problems (if there are any) good luck gettin the money to fix the stuff.
Basically if you didnt read my novel....Dont drop a new engine, dont rout AC, dont half a$$ it. Do it the right way and spend the money, but then think "maybe i should just buy a better car"
My only question here is : Whenever I press the atomic supercharger boost snowflake button -would the road become blurry like I'm going into hyperspace like it did on "The Fast and the Furious" ? DT
I didn't mention the part about replac'in the refrigerant w/ nitrious[8D]
It is a sweet and simple little green sportster sort-of a retro kinda feeling and worth keepin'...
....and man(!) 40 miles per gal. DT
#1 What is a "cold air intake" ?
#2 Who makes 1.8L engine headers ?
#3 "Performance cams" awesome! Who lists these for a 1.8 ?
#4 "good plugs and wires" --got it.
#5 "performance distributer" ? for what ? hi-voltage maybe? hotter spark?
will this better my acceleration ? Does anyone have any
experience with adding a performance distributer ? What does this
do for you ? Can maybe a high energy ignition add-on be an option
here ?
#6 The new clutch I installed is smooth. I aint mess'in with it.
DT
heck ya dude spend 1,500 to 2,000 dollars on upgrades for a 1.8 with 92 hp that will take you to around 130hp. and still get passed by a buss.or spend 1,500 to 2,000 on a 1g gst or gsx and start with 215 hp. then sell that 1.8 and put the money back into your new car. all cars have problems with them,you just have to learn how to work on them your self so you can save money.if you take to a shop and pay 100 bucks to put on a cold air intake etc. then yea you will run out of money quick. so get a chilton manual and a gst or gsx, get some grease on your hands and give her hell [sm=smiley20.gif]
