How much power will i have?
Heres what im planning on ordering (all from slowboyracing)
-SBR Stage 2 2.4L 4G64 6 Bolt Short Block Stage I 2.4L block: • Manley I-Beam Rods • ARP Rod Bolts • Wiseco Racing Forged 8.8:1 Stroker Pistons • Clevite 77 Main Bearings • Clevite 77 Rod Bearings • 4G64 2.4L Block, 4G64 Crankshaft • Block Surfaces Are Fully Decked Lightened and Balanced crank • 800 whp -New Stage 5 head hot tanked bead blasted fully pressure checked sbr competition valve job new valve stem seals stainless steel swirl polished and undercut valves new valve guides fully decked head surface maney valves w/ manley s&b -all new bolts (valve cover,exhaust manifold,flywheel,water pumu,o2 housing...ect) -Fuel Rail Spacers -SBR Tank to Filter Fuel Feed Kit -Aluminum 16 Gauge EGR Block Off Plate - OEM Water Line Kit (1G) -O2 Sensor (Model: 1G) -Mr. Gasket 6AN Billet Fuel Filter. -Mitsubishi OEM Turbo Oil Return Line (1G) -Earls Oil Feed Line Filter - 6AN Fuel Rail Outlet Fitting -6AN Fuel Rail Inlet Fitting -Aem adjustable camshafts & pulley kit -AEM EMS (1G / 2G DSM GS-T / GSX & Galant VR4) (Model: 1G DSM (AEM 30-1300)) -Prothane 1G DSM 4G63 Motor Mounts (Color: Red) -SBR Fuel Filter (1G / 2G) Bottom Fitting -Symborski Shifter Kit (Model: 1991-1994 Eclipse/Talon/Laser)(stiffen up the shifter in manual transmission Diamond-Stars) -1G short throw shifter kit What turbo,fuel rail,injectors,exhaush..ect do you recomend? Basically i want to know how much power ill have with that and what ill be running. (i have a 92 plyouth laser rs fwd) and is there anything else i need and is there anything i listed that i dont need? |
RE: How much power will i have?
800whp.Nuff said:eek:
are you asking how much power you will have after these upgrades? you asked the question in the title but you didn't say anything about it in your post.
All depends how you tune it. I think with that you could get like 800 out of it with good tuning. Maybe even more.
ORIGINAL: Sebba All depends how you tune it. I think with that you could get like 800 out of it with good tuning. Maybe even more. |
