I need Help MY car is over heating
I need help my car over heating I have a 1997 eclipse and i have no clue what it could be [X(][&o].
RE: I need Help MY car is over heating
Well you could start with the obvious first and change the thermostat. If that doesn't help then it's possible that the water pump is shot. Also check your coolant to see if it looks foamy at all and check the oil for milkiness.
does your coolant boil? if so replace the cap and bleed the system. if it just overheats replace the thermostat and add some plain water.
Yeah ro you could try that and see what happens.
