I think we need to have a update!
Ok i think we need to add some updates to the gst/gsx sticky here is what i have in mind.
Gsx/Gst have what is known as a 4g63 this is the block that is in the car. 4g63 block are very reliable blocks and can take a lot of moding on stock internals. In the 1G model they produce 195HP stock and in the 2G model 210HP stock. These motors are well capable of producing 400HP with the correct mods. *added* 1G 4g63 89-92 are what is called a 6bolt block this means the flywheel has 6 bolts and these are stronger motors 93-99 are a 7 bolt motor and while still a very strong motor very few are prone to crankwalk. Now don’t let this scar you too much very few are prone to it but it dose happen catching it early is the key to preventing it from doing further damage. Some symptoms of crankwalk are as follows: Clutch sick when disengaged or while making a left hand turn, shifting trouble, petal engagement may become sporadic at different heights these are early sighs, and ticking noises coming from the lower timing belt cover This may be a sign that the crank angle sensor has been hurt in the process and replacing it will not fix the issue. The only way to fix the issue is by replacing the crankshaft bearings. *added* The first thing you will need to do to your car is making sure it is in good mechanical order. Moding before this can result in motor failure or damage. First give it a good look over just to make sure there are no visible defects that could cause you to regret the mods later. The next step is to do a through tune up of the car. In this tune up you will need to do regular maintenance on a schedule. Some of the things to do are as follows: change all filters, check all fluids change if needed, changed cracked or leaking gaskets, change or change plugs and wires, check compression of motor, change regular belts, check timing belt. If there is any visable damage to the timing belt change it. Also if your car has had over or very close to 60k on it and you do not know if it has been changed change it. If the timing belt is to break it will cause a lot of problems with the head such as bending valves and or cracking head. To do some of these and for other maintenance items refer to an aftermarket manual such as Haynes or Chilton this is a must if doing any mods. Now to go on the mistakes many people make at first. Turbo: Getting a huge turbo this is a mistake by many newbies. Without the supporting mods a huge turbo can cause a car to run poorly. Loud BOV “Blow Off Valve” : Many new people want the pssshhh sound right off the bat. To make the loud sound requires you to vent the bov to the atmosphere. This can cause some performance problems because the stock ecu compensates for that burst of air going back into the intake. This can cause negative effects on performance. To much boost to soon: Same as trying to put a bigger turbo on if raised too much without supporting mods may cause car to run poorly. There are many other ways we can go on about things like lowering springs and other mods that will for the most part not make performance significant change. On to the moding there are several stages we will break down the moding of a car. Stage I: There are several mods that can be done without buying parts some of the people on this forum have talked about and some have not been talked about. Intake: you can cut the air intake box so that the restrictive holes in the box are not the only thing letting air in rather than buying an intake. Second is cutting the rear portion of the inner fender behind the SMIC to allow more free flowing air movement also make sure the SMIC is free of obstructions. BCS: Remove the BCS restrictor. This will allow you to up the boost 1-2psi without problems. These are the basic things that will allow you to get a little more power for no money Stage II: This is where the money as well as the labor will begin. A stage I car can varying cost depending on brand name/new/used parts. Intake: This will allow better flow that the plastic stock tube Second is you need to see how much boost you are running. To do so an aftermarket boost gage is needed this will help with tuning as well. BOV: In order to run higher boost levels you will need to invest into one because the stock on will only allow so much boost. After this it is suggested you get a boost controller they come in electronic and manual version. If you are planning to run over 25psi a manual controller may be right for you. Exhaust: full cat back exhaust system more flow in the exhaust will mean more power and faster spooling times. If you are going for a high hp motor a 3” system is suggested. As well as a higher flowing down pipe, o2housing, and exhaust manifold. Fuel System: Upgrade the fuel system that will be needed for that larger turbo this is not needed until 16psi but is recommended before that to upgrade to minimum of a 190lph pump a bigger one may be needed for your application. Intercooler Piping: Intercooler Piping is the next item that will needed to be upgraded the solid polished piping will allow better air flow from the turbo to the intercooler and to the intake. Turbo: It is suggested to get a t28 if you are staying at stage I or a 16g or 18G turbo. Some kits may need special adapter or installation materials make sure to check before purchase so all of the items can be received. Note 2G eclipse come witha t25 turbo which is maxed out. 1G come with a TD05. Other things that are suggested at this time are Drivetrain: Clutch or auto transmission upgrades and limited slip differential. Stage III: Now we have the mechanicals well covered it is time to move on to tuning end of it. Data Logger: Data logger device of some kind. This will let you know what the motor is doing as you are tuning it and making adjustments. Along with this it is a good idea to get some kind of warning meters. This can tell you important information about exhaust temp, what the o2sensors are reading, and fuel and air mixtures of the car while driving. Fuel and Air Managment: fuel and engine management system. This will help you with controlling the flow of fuel to the larger injectors. The stock system cannot make theses changes. Injectors: Replacing the stock injectors with a higher flowing injector. Research how much flow you will need for the size turbo you have. Intercooler: A better intercooler the stock intercooler is not efficient enough to cool the amount of air you will be pushing into it. Whether you choose a FMIC or a SMIC make sure it will cool the correct amount of air. Other things that may need to be upgraded Drivetrain: Clutch and flywheel or auto transmission if needed. REMEMBER ALWASE RESEARCH YOUR PARTS BEFORE BUYING THEM! |
RE: I think we need to have a update!
please lets as a whole give some input on what else sould be added or changed.
96-99 Spyder GS: These cars have what is known as a 4g64 block that has a SOHC "Single Over Head Camshaft" head this block is a 2.4l. While still a reliable motor they are not quite as internaly strong as a 4g63 DOHC "Dual Over Head Camshaft" head motor this block is a 2.0l. The 4g64 motor is not prone to crank walk like the later 7bolt 4g63 are.
The first thing you will need to do to your car is making sure it is in good mechanical order. Moding before this can result in motor failure or damage. First give it a good look over just to make sure there are no visible defects that could cause you to regret the mods later. The next step is to do a through tune up of the car. In this tune up you will need to do regular maintenance on a schedule. Some of the things to do are as follows: change all filters, check all fluids change if needed, changed cracked or leaking gaskets, change or change plugs and wires, check compression of motor, change regular belts, check timing belt. If there is any visible damage to the timing belt change it. Also if your car has had over or very close to 60k on it and you do not know if it has been changed change it. If the timing belt is to break it will cause a lot of problems with the head such as bending valves and or cracking head. To do some of these and for other maintenance items refer to an aftermarket manual such as Haynes or Chilton this is a must if doing any mods. The 4g64 while still a good motor has a downfall of limited aftermarket parts. Most aftermarket parts are very hard to fine for this car and most people will resort to homemade parts that work just as well as a part you would buy from a dealer. Intake: CAI is recommended as a first upgrade to let the motor breath these have often been homemade for the fact there is a hard time finding this par for a 4g64. Exhaust: A cat-back exhaust can also be used to help the engine breathe. For a naturally aspired engine, 2.5" diameter exhaust is sufficient. Header: A header is another part of the exhaust system that will allow the engine to breathe. The quicker the exhaust can be moved from the engine, the more power that can be made. Ignition System: There are several components in the ignition system that can be upgraded to a better performing part. First off as viewed in the tune-up section, hotter plugs and better conduction wires can be an easy upgrade. If you want to go an extra step, a better coil pack or distributor can be added to the car along with a blaster coil. These items allow more spark to flow through the upgraded wires. The blaster coil will spark 2-3 times rather than the 1 time the stock one does. All of these result in a better fuel burn, which will add HP and better gas mileage. 4g63 Head Swap: A common swap that is made on these cars is the head. A 4g63 head can be put on the 4g64 block with some time and patents. best way to go about this is to ask others that have done the swap in the forum community. Forced Induction: Now There are different ways to go about this. First off if the 4g63 head swap has been done a sock turbo kit off of a 2G 4g63 motor can be fitted with some fabrication to the car. The second option is to find a dealer for the parts or build your own kit. When done fuel management system will need to be added depending on boost range you are looking for. Parts needed to make your own kit: 2G 4g63 exhaust manifold and 02 housing including all gaskets. 2G 4g63 down pipe including all gaskets. Turbocharger Including all install parts "gaskets, crush washers, supply and return oil lines ......" Boost Controller Intake with a High flow filter " must adapt to mas" intercooler with all IC piping and BOV. EGT "exhaust gas temp" gauge and boost gauge injectors and bugger fuel pump 190lph or bigger. Data logger and SMIC Supercharger: Another way of forced induction is ran on belts not exhaust. Its very hard to find for any DSM when it comes in kits like the turbo. Nitrous Oxide AKA N20, Go-Go Juice: This is a fast way of making bolt on power that is cheap and easy, but it also can damage your motor if not done right. It can also cause damage if the kit is too powerful for the engine. This is known and as dirty racing by some racers because it is a cheep inexpensive way to make big power. REMEMBER ALWASE RESEARCH YOUR PARTS BEFORE BUYING THEM! |
i think something else that should be added is links to the actual parts. even though we did these write-ups, we are still getting the questions of which intake is better or which exhaust is better.
only problem with this is when i did do links they were removed because moderator said they are not a sponsor and we cannot support there site or link in this case because of this.
so we can only post links of sites that are sponsors of this one? please tell me thats not true
im not sure 100% ill pm a mod.
ORIGINAL: eclipsed4u i think something else that should be added is links to the actual parts. even though we did these write-ups, we are still getting the questions of which intake is better or which exhaust is better. On the other hand the difference between a apc walmart cone filter and a k&n cone filter, their is a obvious quality difference. |
i was thinking more like i did for the 3G(it is stickied at the top). like for intakes, i listed the companies that have good intakes. then i gave a link to NOPI who has just about every intake for the 3G listed. so its not like i was advertising for NOPI, they just have all of the intakes on one page, so thats why i chose them.
