idle stutter
Old 03-01-2007, 12:35 AM
2nd g eclipse gst's Avatar
Default idle stutter
i have a 95 gst and my engine is like i can i put it without sebba making a sig out of it, well its like stuttering, the check engine light isnt on but could it be a bad censor???
Old 03-01-2007, 12:40 AM
Default RE: idle stutter
well when its idling does it sound like its gana die or is it just a sputter every now and then
Old 03-01-2007, 12:41 AM
nick_200321's Avatar
it could possibly be a sensor(not censor lol) and it could also be the fuel filter. when it the last time you had it changed. it may be clogged or just old. im not a pro with mitsubishi's but with most cars it sounds like you might just have trouble getting the gas to the engine
Old 03-01-2007, 12:47 AM
like it sputters over and over and fuel filter was changed like a year ago
Old 03-01-2007, 12:52 AM
just a thought have you checked your sparkplugs
Old 03-01-2007, 12:57 AM
havent checked em yet problem just started tonight so prolly in da mourning
Old 03-01-2007, 01:14 AM
that would be a good thing to do you may have a few fowled spark plugs i did when i owned a ford tempo and it did the same thing at idle i checked the spark plugs and 3 of them where completely fowled i replaced them and it ran like it should
Old 03-01-2007, 01:24 AM
sounds like plugs to me.
Old 03-01-2007, 03:43 AM
ill fill yall in 2morrow....
Old 03-01-2007, 10:26 AM
RCJr9186's Avatar
is it only at idle? is there any difference from before when you are gettin on it?
Quick Reply: idle stutter
