Indiglo gauges
Old Apr 25, 2005 | 03:41 PM
XskiesoffireX's Avatar
Default Indiglo gauges
I have a 95 Eclipse I just installed indiglo reverse gauges in. The only problem is I have no idea how to wire them, the instructions were pretty bland, hook it up to the headlight power switch, red to positive black to ground negative. Help, someone?[:-]
Old Apr 25, 2005 | 07:42 PM
wicked_outlander's Avatar
Default RE: Indiglo gauges
well, just follow the stock wires diagram.....
Old Apr 25, 2005 | 08:27 PM
Laxstar785's Avatar
just run ground to the chassis.... you can put it anywhere, then run the power to any wire that turns on when the headlights turn on.......in my old honda there were extra electrical connectors in the fuse box, on the floor, on the drivers side. Never even looked for that yet in my eclipse I have only had it for like 3 weeks. if there is one just use a volt meter to test when there is power on each one, if they are there, there should be one that only has power to it when you turn the headlights on. If not take Outlanders advice and use a wire diagram to find a wire.....
Old Apr 25, 2005 | 11:13 PM
DSMTalonAWD51's Avatar
u should use the stock ones...
Old Apr 26, 2005 | 03:04 AM
Sanguinius's Avatar
there SHOLD have been a wire running into the original gaugepod that would have provided power to the lighting that would be a perfect sourse for the power for your gauges. [sm=smiley2.gif]
Old May 1, 2005 | 12:02 PM
No, the way the old gauges lit up there was no wire that connected to it, it plugged into something at the back I duno... Thanks for the help guys.
Old May 2, 2005 | 01:45 AM
Sanguinius's Avatar
Exactly there was SOMETHinG that provided power to the lighting in the gauges. if you can find that wire (Whether it's in a plug or not) you SHOULD be able to splice the indiglo into it.
I Drive Naked
Sep 26, 2011 12:21 AM
thehintons06
Aug 13, 2006 05:29 PM
XskiesoffireX
Nov 15, 2005 10:18 PM
Eclipse4ever01
Jan 20, 2005 03:26 PM
heypeck1
Feb 20, 2004 02:33 PM
