-   -   Indiglo gauges (https://mitsubishiforum.com/forum/2nd-generation-63/indiglo-gauges-4111/)
XskiesoffireX Apr 25, 2005 03:41 PM
Indiglo gauges
I have a 95 Eclipse I just installed indiglo reverse gauges in. The only problem is I have no idea how to wire them, the instructions were pretty bland, hook it up to the headlight power switch, red to positive black to ground negative. Help, someone?[:-]
wicked_outlander Apr 25, 2005 07:42 PM
RE: Indiglo gauges
well, just follow the stock wires diagram.....
Laxstar785 Apr 25, 2005 08:27 PM
RE: Indiglo gauges
just run ground to the chassis.... you can put it anywhere, then run the power to any wire that turns on when the headlights turn on.......in my old honda there were extra electrical connectors in the fuse box, on the floor, on the drivers side. Never even looked for that yet in my eclipse I have only had it for like 3 weeks. if there is one just use a volt meter to test when there is power on each one, if they are there, there should be one that only has power to it when you turn the headlights on. If not take Outlanders advice and use a wire diagram to find a wire.....
DSMTalonAWD51 Apr 25, 2005 11:13 PM
RE: Indiglo gauges
u should use the stock ones...
Sanguinius Apr 26, 2005 03:04 AM
RE: Indiglo gauges
there SHOLD have been a wire running into the original gaugepod that would have provided power to the lighting that would be a perfect sourse for the power for your gauges. [sm=smiley2.gif]
XskiesoffireX May 1, 2005 12:02 PM
RE: Indiglo gauges
No, the way the old gauges lit up there was no wire that connected to it, it plugged into something at the back I duno... Thanks for the help guys.
Sanguinius May 2, 2005 01:45 AM
RE: Indiglo gauges
Exactly there was SOMETHinG that provided power to the lighting in the gauges. if you can find that wire (Whether it's in a plug or not) you SHOULD be able to splice the indiglo into it.
