INFO ON FLOODING
Flooding of what kind? There is 2 that i can think of. One is when you get water in your engine and thats easily avoided... just dont be a fool and drive through a 3 foot deep puddle. The other is flooding it with fuel and just drenching your spark plugs. This can be avoided by not leaving your foot on the gas with the engine off lol.
uhhh... fuel flooding?
flooding happens when too much fuel gets into your combustion chamber, to the point where there just isnt enough spark to light SO MUCH fuel.
You shouldn't get it unless your injectors are broken, or just some piece in your fuel system.
In a carburated car, its easy to get. If you pump the gas for a while, eventually the carb and cylinders will just fill up with fuel.
This is only solved by waiting for the fuel to leak out, or crank it over until all the excess fuel goes out of the exhaust.
Or you can empty your cylinders out by taking out the plugs and letting the fuel shoot out of the plug hole.
You can floor the pedal all day long in a fuel injected car tho, and nothing will happen.
If you do flood your car, something is pretty wrong, and needs to be checked out. You shouldnt drive, if its flooding.
ORIGINAL: Jeffisdecentttttt
[IMG]local://upfiles/4562/C4927D4F2DBA4D36BA09F8CF891A9A31.jpg[/IMG]
