injector size
i was looking at this fuel system
http://www.slowboyracing.com/more.php?id=4938& and was wondering...what is the difference between injector size? is there any downsize to just getting the 750 as opposed to the 550? There is hardly a price difference, and unless there was some sort of negative consequence, i would just get the 750s I dont have a 16g yet, but plan to by end of summer. |
RE: injector size
750s are over kill for just a 16g, unless your going to run over 24psi.
RE: injector size
Well theres always that thought of "someday maybe"
But would there be any negative repercussions of having them on the stock turbo, or 16g? What kind of hp would one be at, at 24 psi? |
RE: injector size
aprox 360 with 24psi.
It wont harm anything and it wont cause any problems... you just wont be using them to anyware near full capacity. |
RE: injector size
ORIGINAL: Sebba aprox 360 with 24psi. It wont harm anything and it wont cause any problems... you just wont be using them to anyware near full capacity. |
RE: injector size
ORIGINAL: Sebba It wont harm anything and it wont cause any problems... you just wont be using them to anyware near full capacity. But thats correct right? |
RE: injector size
as long as your tuned correctly, no they cant do dammage.
RE: injector size
Well ... put it this way. a 16g, injectors, fuel pump, SAFC II and MBC pushes out 346 with a good tune... so... i just estimated.
RE: injector size
ORIGINAL: Sebba Well ... put it this way. a 16g, injectors, fuel pump, SAFC II and MBC pushes out 346 with a good tune... so... i just estimated. |
RE: injector size
I got it from a very good source that i trust. Im just passing on info... What i meant by good tune was a good tune on the SAFC
EDIT: Sorry i forgot that i added a decent FMIC into the equasion when i asked the guy... my bad i totally forgot. |
| All times are GMT -5. The time now is 08:19 AM. |
