installing safc II
Old Apr 16, 2007 | 03:04 PM
austinw23's Avatar
Default installing safc II
would you need any special tools to install this? can anyone do it in their own gargae? should i take it to a specialist? same goes for the mbc should i have some a pro do it?
Old Apr 16, 2007 | 03:07 PM
Default RE: installing safc II
You can do both yourself. They are very simple installs if you can splice wires then you can do it. And the MBC is even easier. Check out www.vfaq.com for how to's on both of them
Old Apr 16, 2007 | 04:25 PM
TheAdvocate's Avatar
With all of the right stuff you should be able to hook up a mbc in 10-15 minutes.. Doesnt take long to hook it up, but you will want to test it to see what boost your running at after that..
92_laser
1st Generation
Jan 22, 2006 03:15 PM
antlip
Dec 27, 2005 08:44 PM
chrispimpryan86
Dec 8, 2005 12:26 AM
16psi eclipse
Oct 1, 2005 01:51 PM
1320a
Mar 6, 2005 10:00 PM
