Intermittant Anti lock ABS light and Code 53
Old Mar 10, 2011 | 06:22 PM
Crashdot's Avatar
Default Intermittant Anti lock ABS light and Code 53
Greetings,
I have a 1999 Mitsubishi Eclipse GSX that has developed an intermittent Anti lock ABS light and Code 53. Sometimes the car will go for a week at a time with no problem, while other times the light will appear every day. I can usually resolve the problem by shutting off the car and re-starting it. The ABS definitely works once the light is off.
Can anyone suggest if this problem may be due to an electrical problem, faulty ABS relay, faulty ABS motor and pump, debris or air in brake lines, or low alternator output?
I want to avoid replacing the ABS motor if without confirming that is the cause of the problem.
Thanks
Akmikek
11
Jul 16, 2021 11:22 AM
whippau
Jul 1, 2011 11:20 AM
chevy047
Sep 1, 2007 08:10 PM
blankjk
May 15, 2006 11:18 AM
