IT'S JUST F'ED UP! I NEED HELP
ok its a 1998 eclipse GS this is what it does it will run fine then start bogging out like its not getting the fuel it need (not the fuel filter already changed it). then sometimes it wont rev. past 4ooo rpm and it idles at 500-600 rpms not normal it usually idles at 950-1000 it guzzles gas like a mo fo when it does this little help please if you have any questions ask me!
RE: IT'S JUST F'ED UP! I NEED HELP
Did you check fuel pressure? What do your plugs look like.
yea its getting the fuel because you can smell the fumes the are pretty heavy when this starts to happen
Yeah but you might be getting too much fuel thats why I said to check the fuel pressure. Are the plugs fouled?
please DO NOT make double posts. You only need one.
I still think it could be a map sensor |
i'll check thos out
