just bought 96 gst
im taking it to a dyno this weekend and i just wanna kno what i should be expecting hp wise from my car. it has a turbo back exhaust, 3in, injen cai, boostin at 15psi,
RE: just bought 96 gst
Probably around 200 at the wheels.
i guess thats decent
You're pretty much stock. You can't really expect too much out of her.
You'll only get a little more umph with a 3" turboback and intake. Your turbo is the passthrough that is the bottleneck. 15psi from a T25, it's out of breath and it's a good thing for the stock fuel system too. ;) Also, IMO, a CAI doesn't translate into much of anything in a turbo car, the SMIC/FMIC do the cooling job a lot better and more efficiently since they are cooling the hot charged air and not getting ambient temp air vs. engine bay temps. Keep it and get a bigger SMIC (Supra or the likes) or an FMIC, once you utilize one of those, then the CAI will make a difference. ;) |
well depending on the dyno you may even put down less than 200. If you go to a mustang dyno you may only be looking at 170-180 range
ok, thanks silver, ill most likely go with the front mount, it will put more power down than a side mount right? and engineer, why would a mustang dyno make a difference, im just wondering
ORIGINAL: 9eclipse8 ok, thanks silver, ill most likely go with the front mount, it will put more power down than a side mount right? and engineer, why would a mustang dyno make a difference, im just wondering |
ORIGINAL: 9eclipse8 ok, thanks silver, ill most likely go with the front mount, it will put more power down than a side mount right? and engineer, why would a mustang dyno make a difference, im just wondering But the mustang dyno is also refered to as the "heartbreaker" for good reason, haha |
cool thanks guys.now when u say supra smic, is that from a stock turbo supra or is that a maunufacturors name?
stock supra, takes some small modification to get it to fit, but it works nicely
