kinda confused
kinda confused
alright guys i have a 95 talon esi and when im driving down the road sometime it will just cut out for no reason at all...i mean just total loss of power then i'll pop the clutch and it'll start right back up any ideas on what this might be??
RE: kinda confused
when you say it goes completeyl dead, do you mean electrical and all? i'd say check ur battery terminals, u may have enough corrosion to where you'll lose connection for a second then it comes back on.
RE: kinda confused
no like the electrical stayes...i know that b/c the dash lights come on like the ones that come on when you put the key in but dont start it...like the engine shuts down completly...idk its pretty wild stuff i dont understand it...batter and terminals are brand new
RE: kinda confused
hm... when it does run is it running correctly and strong? any hesitation or studdering of any kind? this won't be the whole problem but may help with it, check ur plugs. also check ur wires and distributor coil for any kind of corrosion.
RE: kinda confused
it runs great when it decides to run lol the plugs are brand new i just changed them after i bought the car although i do have a slight idea of what could be the prob...when i was taking the old plugs out i noticed that the plug all the way to the right of the engine on the driver's side was covered in oil from the threads down...a buddy of mine said that this could just be b/c it sat for a while or b/c i have oil coming past my piston rings...idk i should prob check that plug again and see if its still doing it...sometime it will studder a little bit but that usually happens when it tries to die and then doesnt...never changed the wires yet though didnt really have the money to do it at the time...
RE: kinda confused
i had a problem similar to that when my timing belt was messed up and my head gasket was blown... not sure which of these 2 problems was causing my car to have this problem but i'd check ur timing w/ a timing light and see if ur on.
RE: kinda confused
thought about doing that a few days ago b/c a buddy of mine had brought his timing light over to set the timing on a v8 we were working on...ok thanks man i'll try that and see what it does for me...hopefully it'll work out...on more question though...well actually its a small series of questions...would 97 headlight mount to a 95 talon esi correctly...i already have a 97 front bumper up there and it goes w/o saying that the headlights and the bumper dont mount well together...and the car is in fairly decent shape other than the problem i just told you about...how much do you think it would sell for...
RE: kinda confused
yeah def noticed that over the weekend...i got it on there but the bumper cover overlaps the inside corner of the heads just a little bit...it doesnt look too bad but im still getting some 2gb headlights to go on it...they look better anyways...
