Lifter tick in a DOHC??
Alright well we all know that the 4g63 is prone to lifter tick, my question is how can it get lifter tick? We just learned about lifters,cams,valves etc in auto class. Lifter tick occurs in engines with solid lifters when the rocker arm is not propperly tightened down causing it to tick on the top of the valve stem. Well..... there are no "lifters" in an over head cam motor according to my teacher, which makes perfect sense. So now i am very confused (so is my teacher) as to how an eclipse/talon can get lifter tick. Can some one explain this? Ive enclosed a picture of a "lifter" on the 4g63
[IMG]local://upfiles/7199/4E95D65C526648E1B9B02248479A99B5.jpg[/IMG] [IMG]local://upfiles/7199/2B6B7F83EC4048388A198B7CF49CC501.jpg[/IMG] |
RE: Lifter tick in a DOHC??
Lifter tick is just a term it is not really lifters you here
So isnt there a way to eliminate it on these cars? I mean, on a regular motor, you just tighten down the rocker arm
change the lash adjuster (lifter)
to bad there isnt just a way to adjust it without replacing the "lifters"
theyre automatic adjusting, if they tap theyre either being starved for oil or they arent working right
ORIGINAL: racerx55 theyre automatic adjusting, if they tap theyre either being starved for oil or they arent working right |
Well that was an interesting lesson.. i was arguing with somebody that these cars have lifters.
its pretty much the same thing, it just doenst ride directly on the cam and has a different name
