Master bushing kit install - Rear knuckle bushings
Ok, so I looked at my rear suspension and we noticed the bushing at the top of the rear knuckle is shot. We used a small crobar and the knuckle moved front to back by like half an inch. Everything else looked good.
I am assuming this is my rear knocking noise problem? So, uh, how do I fix this? Doesn't look like knuckles are easy to come by. Thanks |
RE: Rear knuckle bushings?
Ok, so I was reading a thread where they mentioned that the bushings come in the Master Bushing kits, like by Energy Suspension, and that I can burn my old bushings out and use a ball-joint press to put the new ones in.
I was wondering if anyone installed the master bushing kit and how well it has improved your ride? Also, is there a write up on how to do all this or some of it? I heard it is a 6-9 hour job. Can anyone chime in on common issues with an install like this etc. Thanks |
well ..
this is not mitsu related, but i did have a complete kit on my scirocco. it was a definite upgrade from stock. the car felt more planted and it cornered a lot better.. also i had Apex springs and bilstein struts all around did help. if you dont have any suspension work done than you might feel a small difference... a bit hasher ride since the poly bushings dont flex like the ruberones do, and that a good thing if you drive your car hard since it will alows you to drive a bit more agresively doe to less flex in the suspension. if you want to get do the whole package... get a good name brand set of springs and struts and then leave the sway bars as the last piece of the puzzle. after that it should be like a train on tracks compared to the stock setup. and with a decent tire/rim combo it will put a smile on your face everytime you take a turn. |
Thanks, that's good to know. I have Teinn SS coilovers. I would like to get the whole kit, but I am trying to find out how much of it I can do myself and how much of it I would have to get help with.
I found some write-ups for other vehicles which have been pretty helpful, but nothing so far for the whole kit. Thanks |
the easiest way is to get a ball joint press and press the old ones out...
while the new ones should be a 2 piece design. but then again.. its different from car to car. the key to "proper" lowering ..( notice i quoted the proper word cuz everyone has a diferent way of doing it ) is to get the control arms to "level" out. thats when i noticed that my old g-tech meter had peaked out |
