MSD Ignition Question
If i get the MSD 4 tower coil pn 8229 should i get the MSD ignition control 2 which is part number 6211 for added performance?
or does the ignition control really help that much, and if it does, are they hard to intstall? |
RE: MSD Ignition Question
had a bad experience w/ dis 2 before, i, dunnoe about the 4 tc ....contact msd for tech. quest.
okay ill talk to them about that thanks.
and dont forget to get a copy of "how to" diagram. when i, about to install my dis 2, theres no diagram for mitsu.eclipse( well, for one reason..they never test dis 2 for mitsu.)
Is this for an eclipse? the stock ignition system is actually quite good and just some better plug wires are all you need for 10 second quarter miles. I dont know if this is going to be money well spent.
Okay that helps but i was upgrading and adding mods to, so i was wanting to upgrade the ingition set up 2, and i didnt know if i had to have the dis 2, or if i could just use the tower, here is the list of mods in going to add along with things im going to change out Also what is better a K&N (FIPK) or a cold air intake Kit.
Greddy Electronic Boost Controller PRofec B Spec II Aexi intercooler pipe Kit With Intercooler Greddy (BOV) Greddy Turbo Timer Greddy Grex Front Strut Tower Bar Greddy Evo2 exhaust Greddy Radiator Hoses 8.5mm Magnacor KV85 plug wires K&N (FIPK) MSD Blaster Coil Pack Denso Iridium spark plugs Ecsort 8500 radar detector New Battery New Waste gate Spring |
w/ the blaster coil and a 8.5 wires.....you dont need dis 2 bro.
i have the MSD 4 tower coil pack and 8.5 super conductor wires and it seamed to make a slight differance with the higher voltage delivery to the plug.
ORIGINAL: get435 i have the MSD 4 tower coil pack and 8.5 super conductor wires and it seamed to make a slight differance with the higher voltage delivery to the plug. |
not personaly but i hear they work just as well.
| All times are GMT -5. The time now is 09:40 AM. |
